Originally Posted by
Syd118TSI
I put the 730C (9w7) in the same time as putting in the RNS510 and it all works perfectly. The install wasn't hard, I mounted the bluetooth behind the climate controls below the RNS510. I used cable ties to hold it in place to prevent any potential noises/rattles. The cabling connects into the stereo connection, a couple of passthrough mic connections, then the mic cable gets run behind the dash up the a-pillar across the roof to the mic housing. SHould be able to do it all yourself without too much hassle, the cables are all ready to plug in. You'll need a T20 screwdriver to get the stereo out, and a T25 screwdriver to remove the a-pillar trim.
