Take a look at String to ASCII chart, ASCII to decimal convertor, String to decimal converter, string hexadecimal / hex conversion , though I can't see it working with just 7 digits as we'll need 10.
Printable View
I have done it on 2011 golf and it worked but did not ask for
numbers to be put in as hex input. I suspect different phone kit versions to blame I have not had time to check but ill do it tomorrow and
post out come Possibly add australian area number into the equation????
I have tried using vag com and as jefalijas says a hex code is required. i have tried multiple hex combinations but vag com will not allow
number to be stored i suspect vag com communication issue it may be fixed during an update who knows??
But what i have found is if you ask VW dealer to do this it will store a number using there machines, This will be a cost to whoever chooses to have it done...
I've messaged Dana at rosstech with this query. Maybe she has the work around Ill keep you guys appraised.
sorry to drag up an old thread... mine too dials this EU number ... can you reconfigure the default numbers here?... like for pizza, hookers or something useful??
The dealer here programed mine to call Australian VW Assist and their service department; Given that I'll never return to Austral I wouldn't mind changing the numbers. I assume it can be changed via programming easy enough.
I merged these two threads together. There is more information in this thread, including the location of it in VCDS. However, it appears the numbers are in hex format, and I'm not sure anyone has tried it and confirmed it yet.
Just posted in the Mk6 GTI VCDS ( VAG-COM ) codes thread.
After a bit of messing around, I was able to code both buttons on the center roof console for Information (little 'i' picture) and Service/Breakdown (spanner picture) to numbers of my choosing. I now have the breakdown/service button calling VW roadside assistance and the information button calling my VW dealer.
For those interested, under the Telephone module --> Adaption in VCDS there are four items at the bottom of the drop down list. Two for each button, one being a 'roaming' version. The Service/Breakdown coding requires 7 bytes which are entered as their raw numeric values. So for VW roadside I entered 18 00 63 71 81 00 00 (note padding with 0's for the last two bytes). The Information number requires 8 bytes, again pad with 0's for the extra bytes.
Thanks for the tip Jimmy. It worked for me. :cool:
