ok this is a default with the RCD310, it does not go to next channel, instead goes to the next available channel the tuner can find in scanning mode.
As for replacing the station, use the right side knob tune to the frequency you want.
Then simply puch one of the six buttons and hold it in for approx 5-10 seconds. It's just been reset to the new radio station.
I'll also take it your golf/Jetta, only has half height display on centre console?
Also have the two Phone buttons on the steering wheel?
It's a known problem with this combo. If you had full Height Centre display on Gauge Console. You would be able to go thru the list of radio stations and select what you want without having to change the actual radio what so ever. And once the selected channel is choosen, only then will the radio change to the desired station.
Works in CD mode like this too, If you add Bluetooth to your combo, you get no display of who is ringing or contact list.
But if you add voice tags to the numbers you will be able to dial out via voice and when A call comes in it will tell you who is ringing, providing a Voice tag has been configured for number.
