Results 1 to 10 of 18
Thread: Setup menu rns510
    Aug 2011
    Thornlie WA
    Setup menu rns510
    Hi
    Trying to determine my firmware & map revision for my RNS510 (C). Tried
    holding the setup button down, but doesn't go further than the radio menu. Is there
    another trick to get this info. Also who is the most capable dealer in Perth for upgrading
    firmware, maps etc.
    Thanks
    There are two ways to do this. Explained in the link.
    Accessing the Setup Menu on RNS 510 head units with firmware version 2660 / 2662 / 2664 / 2666 / 2668 | my-gti.com
    You don't need a dealer to upgrade the firmware or maps. Its an easy job. At worst find a member in Perth to help you out.
    Mindarie, Perth (WA)
    What do you want upgraded gazza?
    Jul 2010
    From memory, the VIM iso also has the secret menu enabled.
    http://www.vwwatercooled.org.au/foru...ion-61990.html
    So you could enable it this way, whilst also enabling VIM.
    MY11 Tiguan 147TSI (SOLD)
    Jun 2011
    If it already has 27xx firmware then it won't be able to update without enabling downgrade. Best option for upgrade would be to go to the 39xx custom firmware...
    http://www.vwwatercooled.org.au/foru...t0r-65337.html
    Lake Macquarie
    Keeping holding the button down.
    I first tried finding the secret menu while driving and held the button down and didn't pay attention to the screen as some traffic was coming up. When i looked at the screen a minute later i had the secret menu (mind you i have loaded the VIM file mentioned by Aussietig above).
    Anyway, tried it at home again and held the button and it didn't work. I eventually figured out that I had to keep holding it, I think there are two menus that come up before the secret menu and i was letting go at the first screen that appeared.
    Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
    Aug 2011
    Thornlie WA
    My RNS510 is supposed to have voice activation, but can't see how to get it to work, so thought
    a firmware upgrade might help.....but unsure how to proceed as there seems to be much
    conflicting information on the topic. Also my premium blutooth has low & distorted TX so would
    like to address this issue also.
    Apr 2012
    Hey I know this is an old thread but I've been trying to get into the secret menu to see what version RNS510 I have. I don't the coding behind and held the setup button in for over 2 mins and still nothing? Is there another way?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
    Jul 2010
    Quote Originally Posted by Bassik View Post
    If yours is a stock unit, then based on the MY of your Golf, my guess would be that it's a F unit.
    However your easiest option is just to pull the unit out and have a look at the sticker. Pretty easy to do on the Mk6 Golf.
