Results 1 to 8 of 8
Thread: Reboot RCD510
    Jul 2011
    Reboot RCD510
    Does anyone know how to reboot a RCD510?
    Pressing “<” + ">" + [Music Symbol] simultaneously sets it to Transport Lock mode.
    Holding [Setup] goes into the Service mode.
    But what is the reset sequence?
    Edit: I've tried “<” + ">" + [Eject] and it's a no-go
    MY12 MKVI Golf GTI DSG
    MY16 MKVII Golf 92TSI Tendline DSG
    Mindarie, Perth (WA)
    hmmm...why do you want to reset it?
    Without knowing the answer to the question, have you tried resetting/restoring factory default setting from the unit's menu?
    Apr 2010
    Reboot sequence is always < + > + whatever button is next to the Eject button (different versions have different buttons here). Hold them down the same way you would use Ctrl+Alt+Del on a computer, but maybe hold them in for a bit longer (1 second).
    this is the RCD not the RNS
    Apr 2010
    hmm, doesn't the unit reboot each time you start the car when the car has been locked/idle for more than 20 minutes?
    Otherwise check in the user manual. Or disconnect the battery if it's a one-off.
    Jul 2011
    Thanks, I'll check it out later. Reason I ask is I've just got a VAGCOM cable from RT and just messing around with the radio.
    Apr 2010
    You could always use the cable to install the RNS510 - and then you would know how to reboot it
    Jul 2011
    Perth
    Hey guys, I have RCD510 Delphi version.. Never could unlock the CD changer.
    Anyone know how.
    Al
