Results 1 to 4 of 4
Thread: reverse camera
    Ferntree Gully, VIC
    Unhappy reverse camera
    I HAVE A RCD 510 AND WONDER IF YOU CAN USE THAT TO RETROFIT A REVERSE CAMERA OR DO YOU HAVE TO UPGRADE TO THE RNS 510?
    Adelaide hills, SA
    No need to upgrade to RNS510 (you would still not be able connect RV cam directly to the unit), you need the interafce connected to the RCD and camera connects to the interface. Ebay is your friend.
    Nov 2009
    AFAIK, not all RCD-510s are equipped with a video input interface, which is required if fitting an RVC. Certainly with the MkVI GTI, only those cars with an RVC fitted at the factory have the required video interface.
    So you'd be safest taking the head unit out and inspecting the rear to confirm. Check out my-gti.com for detailed info.
    Ferntree Gully, VIC
    thanks all will rip it out and take a looksie
    Black 2007 Golf V Trendline 1.6
    Feel the Power
    RCD 510
