Originally Posted by
Domz
Hi Guys
I have had a RVC retro-fitted on my RCD-510, and find that the quality is quite low compared to other cars.
Also the brightness is very low, is not light-sensitive, and the adjustments on the screen do not function.
The fitter claims that this is due to the unit not being the GPS version, the resolution will be low and you cannot control the brightness.
Does anyone else have a RVC on there RCD? and how is it?
Also I do not have the guiding lines, just the image. Can this be added in aftermarket?
from what I see on youtube videos mine works very similar in terms of brightness and photosensitivity....mine is tho factory installed with rcd but am looking to change to RNS (still thinking if 1000 euros is worth the features).
GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
