Don't laugh, I grew up in Newcastle plus Im in retail food. I've seen some winners in life. It's scary
lol seriously?
Just shoot those types of people and get them off the roads. If you 1) forget to press a button and then 2) are so stupid to run into a wall because something didn't beep at you, then you don't deserve to live let alone drive
2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
Hi all,
Apologies if it appears I am hijacking this thread, but I have a few questions along the same lines of the original post.
I have a Skoda Octavia (2008 vRS) with factory rear sensors. I have retro fitted a RNS510 (Skoda Columbus) unit and the Skoda bluetooth kit, both coded correctly and working well. Prior to the upgrade, I had both parking display and dual zone climate display in the 'Audience' head unit
The Columbus is a revision 'A' unit, running firmware version 2764
From VCDS, the car is fitted with the following canbus and controller:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087170117
Coding: ED807F0E4006021303
Shop #: WSC 73430 790 00000
VCID: 356BD69A25D1
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0001021
VCID: 3D7BCEBA1DE1
Could someone advise what I need to do in order to get the displays back, or recommend somewhere in Brisbane to get this sorted?
Thanks
Tom
I bought one of these kits (front ans rear) but decided not to install them. $400 sydney pickup or pay additional for postage. PM me for details.
Should post on fs forum might get a better response
Ok so I've finally done a lot of research (and I mean a LOT) about the issue of various PDC's not working with various cars.
The simple answer is that PDC's with numbers ending in ??? 919 475 are the same product but the SW is customised for specific types of cars. The reason people get errors with 3C8 919 475 is that this unit is for the Passat, and it's got components not found in Golfs or Jettas (one notably being the electronic parking brake which will always give out errors because they're not present in Golfs).
MKVI's and late model Jettas use PDC 5K0 919 475, which, I've just discovered is being sold by carsystems.pl!!! Specifically, 5K0 919 475 C, though the Golf R comes with 5K0 919 475 D.
If you've got a car that was manufactured this year (2011) then there is a good chance you will want 5K0 919 475 D and you wouldn't encounter any problems at all!! The commonly sold 3C8 and 1K0 are very old PDC's which were meant for older cars.
I'm not an authority on this (obviously), but one thing I remembered a guy pointing out that late model Golf and Jetta owners should avoid 38C as they're for the Passat and it WILL cause errors even if it'll appear to work. Hope this helps people here.
---------- Post added 20-12-2011 at 05:18 PM ---------- Previous post was 19-12-2011 at 05:51 PM ----------
Just wanted to update everyone that T-Era sent me a 5K0 PDC instead of 3C8 even thought the eBay listing stated 3C8. The seller told me that the 3C8 indeed had some compatibility problems with some VW cars. I'm very happy as it is the correct part number for the 2011 Jetta.
ImageShack® - Online Photo and Video Hosting
Hi would these suite a 2008/9 golf gt sports with reversing sensors already installed ??
This sale includes:
•PDC control unit (part no. 5K0 919 475 E);
•4 parking sensors for rear bumper and 4 sensors for front bumper (part no. 3C0 919 275 S);
•8 holders for parking sensors (for fitting into bumper, with 2 side tape, part no. 1Z5 919 491 C);
•Wiring for sensors (conects parking sensors to PDC control unit; 2 separate wiring);
•CAN BUS wiring (goes from front of car to the rear where PDC Control Unit is located);
•2 beepers for audio signals (part no. 8E0 919 279);
•Button for activating sensors (automatic when reversing but can manually activate if required) (part no. 1K0 927 122 A).
Hi, I bought the T-Era front and rear OPS unit (from get4less) which included the 5K0 919 475 E PDC. George at VW Village fitted it too my MY 2011 Golf a few days ago and the button didn't work and I seem to have to reboot or reset my RNS 510 to make the OPS screen visible (the beepers beep away) after every second start.
Any thoughts on what it could be? I'm getting a HEX-CAN cable in the next week so I'll have a good look around but has anyone else had these sorts of problems and solved it?
MY 2011 Reflex Silver 118 TSI DSG MDI. Retrofitted RNS 510, RVC, 9w7, Front/Rear OPS
ive only got the rear OPS. derek at european autotech did the install. he spent a lot of time on it, but it works 100% no worries.
give him a call
