Results 1 to 9 of 9
Thread: New map on skoda portal 23 june
    Pacific Paradise QLD
    New map on there this morning for Discover PRO 25GB Map version HIGH12_P97
    Nov one was P90
    Is really slow even on a 250 account Must be whole world d/loading it
    Took 4 hrs to d/load 40 mins to unzip and 40 mins to install in car Works perfectly in Skoda and VW
    Jun 2007
    Wellington Point, Brisbane
    Hi Hillbilly, downloaded the latest map and loaded into car. Seemed to load OK but I forgot to remove the sd card so the map upload started again. I stopped it at 1% now I get Navigation database not available. Tried a reboot with the same result. The sd card is recognised momentarily but I can't get past the Navigation database not available message. Any suggestions?
    2019 Skoda Superb 162kW
    2014 Skoda Octavia Elegance 110Tdi sedan (sold)
    2005 Audi Allroad TDI (sold)
    1968 VW Country Buggy (KO 606)
    Change SD slots maybe. I loaded mine with car running in the garage and when I got back it had completed but gave an error but said on the screen it had updated it. I restarted it and turned it off after 31% so will see when I use car tomorrow what happens.
    It should reload over itself so not sure what has happened.. Maybe use a different SD card and try that
    May 2007
    I did my latest update on Thursday. Download took all of an hour. Copied to SD Card. Installed in car whilst on the CTEK Charger, took about 35mins. I have never had an issue with this process over the past 4yrs, will do the Passat over the weekend also.
    Jun 2007
    I've never had this issue before. Sorted by using the general software upload option.
    Oct 2013
    Did you update the Kamiq with that map Hillbilly?
    Which entertainment unit do you have?
    2021 Kamiq Monte Carlo
    1.5 DSG Moon White
    Quote Originally Posted by mummbles View Post
    No my Kamiq has been sitting in the ship waiting to go through the Panama canal for last 3 days.
    Did the Tiguan as per my sig and the unit is as I said in original post.. My dealer said THEY will update Kamiq's maps at service (hopefully)
    Jul 2010
    doesn't the Kamiq come with the MIB3 unit?
    hence these maps won't work as they're for the MIB2 and MIB2.5 units.
    the MIB3 unit is a different beast.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Quote Originally Posted by dArK5HaD0w View Post
    You and I are onto it LOL
