are you sure theres a speaker in there? I think its a ventilation diffuser isnt it?
Heres some instructions anyways if its that grille youre trying to remove?
http://vr6.com.au/images/centre%20diffuser.pdf
Hi Can anyone assist me with unclipping the centre speaker on the dash in a 06 passat, see image I have managed to unclip the sensor? in the middle and unscrew the screw under it but that is as far as I got as I did not want to damage the grill.
Thanks
Peter
[IMG][/IMG]
thanks i'll have another go/look at it!
it says there is a bolt underneath the sensor. Are you able to get the sensor out? does that give you access to whatever it holding it in?
yeah i can get the sensor out and the bolt, i originally thought it was for a centre speaker but it seems as if i am wrong about this. I wanted to put my gps antenna in there out of sight, looks like it may have to sit on the dash![]()
There is not a speaker in there. It has plastic slotted vents under it that would have to be heavily modified to fit a speaker. It is that tight that you would only fit tweeters anyway. I would say, just leave it be.
