Results 1 to 6 of 6
Thread: Upgrading to rns510
    May 2009
    Canberra
    Upgrading to rns510
    Hi all, I currently have the old RNS500 blaupunk model in my 07 Passat I'm thinking of upgrading to the new RNS510. What are the possibility of doing this and what update I need to do or should I just leave it as it is.
    From this
    Upgrading to rns510-image-jpg
    To this
    Thanks
    2009 Tiguan TDI and 2007 Passat TDI
    Pacific Paradise QLD
    Thumbs down
    Well if yours takes the latest maps Probably apart from costing in excess of $1000 Not a lot
    Need to make sure faceplate is identical.
    Personally I wouldn't bother ATM and wait till the new DAB+ radio enabled model comes out and then spend $2000 + and still have a crap navigation system
    May 2009
    Canberra
    So you think regardless if I upgrade now or later I will still have a crap navigation?
    Satnav is still working and still current map, just the old school image can be a bit annoying and the reversing doesn't have car image just tone.
    Quote Originally Posted by revhead1016 View Post
    Well my opinion of VW navigation has been documented on here My wifes TOMTOM is far superior in every way. and it cost under a 10th of an RNS 510.
    However the other parts of it are Ok Like the HDD for music and the radio is Ok.
    Yes the parking and RVC is good don't know if your sensors would work but find the rear lines in the camera are a bit out as far as distance is concerned. I backed up today and was a lot closer than the lines said to the car behind me.
    Had it not been in the car when my wife saw it in the showroom I wouldn't have got it.
    Was a nice birthday present though ( The car not the Nav) LOL
    May 2009
    Canberra
    No probs thanks mate. Will do some more research before I make a move.
    Mar 2009
    Melb
    You could read up maverick's posts re the RNS. There has been some reports of battery drain when RNS 510 is incompatible with older can bus
    RNS 510 | my-gti.com
    Tig 162 R-Line; Audi TT
