Results 1 to 6 of 6
Thread: RNS510 - firmware upgrade to 3810 - now flickering screen? Seen this before?
    Camberwell, Vic
    Hi all
    Anyone experience this - the firmware upgrade worked fine, as I thought, and everything appears there. Also upgraded to V5 maps. Screen is more sensitive, it's certainly quicker to respond and loads/starts up quicker.
    But, on the night setting, the screen is flickering between various degrees of brightness. Not much, but enough that if you watch you can see it getting slightly lighter or slightly darker as if its not sure what the brightness should be.
    Anyone experienced this? It was a C unit, (1T0035680C) and is now 1T0035680D, running 3810 (upogarded from 2680) and maps 7679
    Have rebooted a few times and going to see how it pans out, but it does seem as if in daylight mode it does NOT do this - only when varying degrees of brightness are available.
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
    Nov 2009
    My C unit (running stock 2680 firmware) does have a variable-brightness screen; I'm sure yours does too. In the top-right corner of the unit is an ambient light sensor, which is used to determine how brightly the screen is backlit. Cover it with your finger and you'll see it dim. When I'm driving along at night with the roof open, I notice it gets brighter every time I pass under a streetlight.
    Camberwell, Vic
    Thanks Adam. This is not that though - you can be stationary and the screen is almost constantly changing....
    Aug 2011
    Melbourne, Victoria
    I've seen this issue before on a version C unit. Try upgrading to 3970. It worked for me.
    Volkswagen RNS 510 Firmware Upgrade to version 3970 / 3974 / 3976 / 3978 | my-gti.com
    Camberwell, Vic
    mythik - you legend. Will try this. Thanks so much...
    ---------- Post added 07-03-2012 at 12:00 PM ---------- Previous post was 06-03-2012 at 02:02 PM ----------
    Quote Originally Posted by mythik View Post
    Just wanted to acknowledge your advice and help - upgraded to 3970 today and it would appear all the flickering has gone. Will test it more at night but certainly it seems to have improved. Interestingly, upgrading from 3810 to 3970 did not require a re-installation of the maps. They just reloaded themselves - I guess the partition remains the same. But many many thanks for your advice.
    Camberwell, Vic
    Yep -- all sorted. Upgrade worked a treat
