Results 1 to 7 of 7
Thread: Rough Costs of wiring Spot Lights and Light Bar on a Amarok
    Newcastle, NSW
    Gday All,
    Ive got a used Amarok with ARB bullbar and ARB spotlights. I was recently given a light bar and i have since mounted it.
    The car is used and the existing spot lights do not seem to work even though they appear to be wired through to cabin.
    I did some amarok forum searching and found that they make Individual Spot Light and Light Bar switches to go in the blank spots next to the gear shifter. I have already bought the switches are would like them installed for each corresponding light.
    Would any wise VW fans know a estimated cost to pay a auto electrian to wire these in ?
    P.S The Spot Lights and LED are already Mounted.
    Volkswagen -Enthusiasten
    Jul 2010
    Robina Gold Coast
    How long is a piece of string ?
    Believeme its not that hard to wire up spots or a light bar
    Id imagine the kit came with a wiring kit and directions
    You only have to use the high beam as a trigger for the relay
    Mar 2017
    Tasmania
    First thing to do - identify the reason the existing driving lights don't work. Could be a fuse, could be something else. But before you start installing new wiring, identify the existing issue.
    Newcastle, NSW
    Thankyou both for your replies. Much appreciated.
    1st quote from auto eleco is $300 - $350.
    Ill see if i can get it down a touch.......
    Jul 2010
    Robina Gold Coast
    There could be an inline fuse or the relay is shot see if the connection to the battery is connected going to the relay ?
    Brisbane, Qld
    This guy does everything electrical for Amarok. Great quality and plug n play harnesses.
    Pragmatic Racing - VW Amarok and Motorsport Electrical Looms
    Jun 2013
    Qld
    Quote Originally Posted by winchy View Post
    They seams to know what they talking about.
    What about a mob near Brisbane. Any recommendations?
    Thanks
