Page 107 of 111 FirstFirst ... 75797105106107108109 ... LastLast
Results 1,061 to 1,070 of 1105
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #1061
    Apr 2016
    melbourne
    Install 5238
    Sent from my SM-G960F using Tapatalk
    Update from SW-Version 2680 > 5238 I assume?
    Do you know of any guide or where I can obtain this software?
    Cheers.
  2. #1062
    Have you maybe read the first post?
  3. #1063
    Sep 2021
    Darwin, NT
    Hi everyone,
    I have a 2013 VW Passat. One day, the language on the RNS 510 turned to German and the sound is gone. The system looks fine, but there is no sound from the speakers. When I try to change the language back to English, the system gets stuck. I also tried the basic things like reset and battery release but didnt work. Please help.
  4. #1064
    Pacific Paradise QLD
    Quote Originally Posted by sheekat View Post
    Hi everyone,
    GOOGLE Regensburg syndrome or/and read this
    RNS 510 points to Germany on cold start everytime
    A bit naughty to multipost same thing across different forums
  5. #1065
    Nov 2021
    Druskininkai, Lithuania
    Hey guys,
    Does anyone have a 6270 or 6276 FW with hdd format and re-partitioning?
    I have a unit with new SSD, which had 6270 FW originally, but the problem is that software downgrade is not turned on, so I cannot install any older FW than 6270. And any 6270 or 6276 version that I can find is failing on HDD 6% error writing file.
    As I went to Software update menu and my updates failed, so I cannot get my unit to work now. Driving in silence is nuts.
    Can anyone help, please?
  6. #1066
    Jun 2013
    Holsworthy NSW
    Hi everyone,
    I think I have the exactly same thing happened to my 2012 Tiguan , the firmware was corrupted and you'll need to reload the firmware and map. I had my RNS510 back to working order after reloading the firmware and map.
  7. #1067
    Quote Originally Posted by someon3 View Post
    Read reply 1064
  8. #1068
    Oct 2022
    Hi everyone,
    I have a 2013 VW Passat. One day, the language on the RNS 510 turned to German and the sound is gone. The system looks fine, but there is no sound from the speakers. When I try to change the language back to English, the system gets stuck. I also tried the basic things like reset and battery release but didn't work. Please help.
    Three days ago my 2012 Skoda Octavia 118Tsi did the same thing! It was working perfectly one day and then the next day on starting the car the display went black and showed the message 'SWL error, Initialising.....please wait' then nothing happened for a long time. Finally it switched to German, cleared the radio of all preset stations , lost all sound and then got stuck when I tried to set it back to English.
    From reading this forum it seems the solution is reloading the firmware and map. I am clueless and don't have any of the equipment such as a burner etc so I've booked the car in at my local Skoda dealer to do it. (Skoda Artarmon in Sydney).
    My questions are
    1. Any idea as to how much is this likely to cost?
    2. What firmware etc should I have installed for the most reliable performance going forward? Should I get the same firmware version reloaded again or is there a better more stable version available now that would prevent this happening again?
    3. If the maps also have to be reloaded, I might as well get the latest version compatible with my unit, what would be the most up to date version that will work with my unit once it has been repaired? Currently I have 7679.
    The hidden menu on my car currently shows the following:
    Delivery part number 3T0035680B
    HW-Version H55
    SW-Version 3984
    Active map coverage Australia + New Zealand
    Active map supplier Sensis
    Map version HDD 7679
    Thanks to all in advance.
  9. #1069
    Quote Originally Posted by Villageidiot View Post
    My questions are
    HW-Version H55
    SW-Version 3984
    Latest map is V10 and only place Ive seen it for sale is Euro Car Performance upgrades - ECU remaps - Navigation - Bluetooth - Latest Australia GPS maps - Auto electrics and is $175
  10. #1070
    Oct 2022
    Thank you, I'll ask my Skoda Service Centre if they have it too. Any ideas as to which firmware I should get to avoid /minimize the chances of any future reliability issues?
