Results 1 to 10 of 11
Thread: Amarok Headunit upgrade
    Jan 2022
    WA
    My head unit touch screen is starting to play up so wondering what options I have for a factory upgrade. I have a 2018 V6 Dark Label. Would it be the RCD330? Not sure what my factory model number is currently. I would really like it to be just plug and play as I don't know anything about coding if that is required.
    Mornington Peninsula, VIC
    The newer Amarok (2020+) now coming with Discover Media, which is probably your best OEM option.
    If you upload a picture of your current unit we should be able to identify it.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jan 2022
    WA
    This is what I have
    Attached Thumbnails Attached Thumbnails Amarok Headunit upgrade-20221010_150018_resized-jpg
    That's a Discover Media. It's the top spec and a very good unit.
    I have some repaired screens coming in in a week or two. Can either send you the screen or you can send me the unit to swap it.
    Jan 2022
    WA
    It's weird that is has only happened since getting turbo and tune. very random and this morning screen was blank but everything working sound wise. Did the soft reset and all came back good.
    Jan 2022
    WA
    Thanks Kamold. Things seem to be getting worse, rather than maybe repair as I assume would probably $400ish to replace screen, wondering if better option is to go after market. What are the best aftermarket android style ones to go.
    I found these
    Volkswagen Amarok Head Unit 2016-2022 - VHEDIA
    and I know some Jeep guys with the Teyes ones but they seem to be a bit finicky.
    Any opinions would be appreciated. I would prefer quality and plug and play
    Jan 2023
    I've got the same head unit with the same touch screen issue. 2018 Sportline.
    Nov 2016
    Perth NOR
    Amarok head unit upgrade
    Quote Originally Posted by Dinogzav View Post
    I found these
    How did you go mate, did you end up with the Vhedia unit?
    Sep 2023
    Perth, WA
    Would this unit fit on an older Amarok with a RCD510?
    Sep 2023
    Perth, WA
    Quote Originally Posted by MIG View Post
