Page 32 of 47 FirstFirst ... 22303132333442 ... LastLast
Results 311 to 320 of 470
Thread: Discover Media retrofit
  1. #311
    Sunshine coast
    Looks like there's a technosat YD7 for sale at $270 in Brisbane on facebook. I believe these are hackable with some hardware mod?
    132TSI Tiguan Allspace
  2. #312
    Quote Originally Posted by Passat rdi View Post
    Hello I have a question about the discovery media pq 5c0035680D. My unit is complete unlocked with also all fec, swap codes. I have also the performance sport hmi display but it,s doesn't work properly. I have set all Adaptions but there,s no info in the screen. Does anybody have a working performance menu in his discover media pq?
    Kind regards passat rdi
    No you can't (as far as I've seen) get this function to work. It's an MQB feature. The only reason you have the adaptation options there is because the software is the same. Doesn't mean it will work.
  3. #313
    Mar 2020
    Utrecht
    Oké the strange thing is that the offroad menu the think blue trainer and parkpilot menu works fine also the drivingschool functie and mfa info works. Vehicle menu and performance doesn't work. I have update my gateway bc to bl but there is no change. The 3aa A bcm to R.
    I think the menu,s are missing som puls.
  4. #314
    Performance monitor requires a swap code in mqb.
    I don't believe such a thing exists for pq.
    Sent from my SM-G960F using Tapatalk
  5. #315
    This looks fantastic and a massive upgrade on RNS510.
    Are you still able to kindly point to where I can get all the necessary parts to have this working?
    I've got a 2008 MKV GTI, no RVC, no parking sensors
  6. #316
    Jun 2019
    France
    If you have original camera I'm guessing you are using an RGBS to CVBS converter? They can be a bit hit and miss. You can replace the camera with a cheap aftermarket composite camera and go straight into the Discover media and get a better picture.
    Hello ,
    I reuse the original VW low camera with an RGB / CVBS « aliexpress « converter.
    As you told somewhere in this thread I connect the « detect » wire to 12V and now I have the rear image on the DM.
    But a really very bad image , moving up and down etc..
    What is faulty ?
    The adapter ?
    NTSC/PAL option to change in Rear camera module ?
    —> But another strange thing : VCDS can’t access to module 6C « rear camera « .
    What can I do to recover access to it ?
    thanks
    Regards
  7. #317
    RVC low has no 6C control module.
    The converters are pretty poor quality.
    Your best bet is to replace the RGBS camera with a CVBS camera. Then no converters involved.
  8. #318
    Jun 2019
    France
    Ok, can i reuse the existing wire , plug the new composite cam and "rearange" the cable for the new camera or do i need to do a complete new wiring ?
    Can you advise me a camera that's fit for Touran 2013. There is so much model , sometimes one detail make the product incompatible.
    Thanks
  9. #319
    Jun 2019
    France
    I found this one , is it ok ?
    € 14,10 23% Off | CCD HD Car Reverse Cam Trunk Handle Car Parking Rear View Camera Case for Audi/VW/Passat/Tiguan/Golf/Touran/Jetta/Sharan/Touareg
    CCD HD Car Reverse Cam Trunk Handle Car Parking Rear View Camera Case for Audi/VW/Passat/Tiguan/Golf/Touran/Jetta/Sharan/Touareg - AliExpress
  10. #320
    You can get good aftermarket cameras with proper dynamic guidelines from steering angle data.
