Results 1 to 2 of 2
Thread: Highline Reverse Camera
    Hi There,
    Wonder if someone can make sense of the connection below.
    I am assuming I'm to solder these cables to the harness with the 1 to 26 pins connector but the
    description below does not appear to match the description on the drawing of the RNS unit.
    VW Amarok High line Rear Camera kit - 2H0907441
    There is four wires: Power (RED), Ground (BLACK) and Can + (ORANGE) and Can - (BROWN) to get hooked up. All of these get tapped behind the RNS/RCD510 and it's worth noting that the pin out is listed on the device anyway if you want to double check:
    Pin 9 - CAN+ (Wire Orange/White)
    Pin 10 - CAN- (Wire Brown/White)
    Pin 12 - Ground (BROWN)
    Pin 15 - +12v (YELLOW/RED)
    The RVC connects on the infotainment bus. So you want to tap the CAN hi and CAN lo connections in the big black quadlock connector which plugs into the back of the head unit. NOT the 26 pin multimedia connector. This just connects to the RVC module itself.
    Same goes for your power and ground. Connect to the power and ground pins in the quadlock harness in the back of the head unit.
    The pinouts which you have listed above are in the left hand side of the diagram.
