This is done by The CAN BUS. For people who dont have rear parking sensors, then stiff luck, u cant have this feature. But for people who do, winning, well get on it, it is the best convenience option!!!
Printable View
It's a big deal for some of us (with Tigs).
Despite having all the so called correct options mentioned and enabling it, it still doesn't fcuking work.
Here's my MFD with it enabled and I do have parking sensors, park assist & RVC.
http://www.vwwatercooled.com.au/forums/
It is hoped that this kit somehow does something different that actually might get it to work.
Hence the discussion. :rolleyes:
Based on my process of elimination, I think mirror dipping has something to do with the door controller module being either completely different or wrong coding in the Tig (as compared to the Golf).
I speak from the experience of having to enable flappy paddles via VCDS on a Tig, because it's just not a setting required to be enabled at factory because you don't have the paddles on the stock steering wheel.
Just need to work out which one is it with mirror dipping.
Don't know whether you recall, but a while back a request was made to you to scan and post up your coding for the doors on your Golf R since you have it working there.
Quite frankly, you're definitely the right man for the job since you've also got a Tig as well.
Anyhow are you able to answer that call now?
hmmm same issue again after firmware update last night and checking and re-checking all conections.
any octavia owners want to let me install on your car to test? :) i can disassemble and reassemble in about 15 mins. im in sydney.
I'm at work all weekend you can crack mine open in the carpark if you like.
i have a wedding this afternoon/tonight. working tomorrow?
