Results 1 to 10 of 18
Thread: Rns 510 - no map display - screen white / black - all else works
Sir_GTI Rns 510 - no map display - ... 11-10-2011, 01:55 PM
Sir_GTI I have fixed the issue. ... 12-10-2011, 10:59 AM
kndkris I am having this same issue,... 06-09-2014, 02:37 PM
Guest001 Do what he says in above post... 06-09-2014, 02:53 PM
kndkris Yeah it tried the settings... 06-09-2014, 03:29 PM
kndkris So far I have tried... 18-09-2014, 10:52 PM
Guest001 Wonder if its got the... 28-09-2014, 08:08 AM
kamold Where are you located? 18-09-2014, 11:06 PM
kndkris I am in Osborne park in Perth... 19-09-2014, 09:56 AM
kamold Ok might be a bit of a... 19-09-2014, 10:54 AM
FJ Steve kndkris...is this an RNS510... 20-09-2014, 07:09 AM
kamold Yes same disk for skodas, vw 20-09-2014, 09:23 AM
kndkris I took it to the Skoda garage... 28-09-2014, 10:19 AM
Guest001 You are wasting your time... 28-09-2014, 10:49 AM
kndkris Yeah I have previously... 28-09-2014, 10:56 AM
Guest001 Did you try this Settings/... 28-09-2014, 11:09 AM
kndkris Yep done all the resets... 29-09-2014, 12:28 AM
FJ Steve I have purchased 2 RNS GPS... 29-09-2014, 09:30 AM
    Mar 2010
    Hi Guys,
    I need some help.
    Have a bit of a problem with the RNS 510.
    I no longer have any maps displayed. Just a white / black screen, with the compass in the top right and the red circle and arrow in the bottom middle.
    Everything else is working fine, radio, menu, lights and settings. I still get all other displays, just a white / black screen on the map.
    Tried using the NAV to an address, all works until you click start, and it says no routes available for this destination.
    I have reset the unit several times, and still no different. I have not updated the unit or messed with any settings. It was working fine last night, and this morning, nothing.
    Hope someone can shed some light on this.
    Thanks
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
    Mar 2010
    Under the setup menu, there is a system menu. I went in there, and I had the option to reset individual sections of the RNS. There were 2 options for the Nav section.
    I selected the 2 check boxes, and reset. I then exited the setup menu, and the map was working fine again.
    Even though I had reset the unit via the normal method < > and Star button, it still had to be done via the setup menu.
    Very handy, as you can reset to factory here, or choose individual items to reset.
    Jul 2014
    Perth
    I am having this same issue, was working the other night and today nothing on the map screen but everything else still working. Have tried both reset methods ( left right and voice button, settings reset) anyone have any suggestions for a fix?
    Sent from my Nexus 5 using Tapatalk
    Pacific Paradise QLD
    Quote Originally Posted by kndkris View Post
    Do what he says in above post Seems it worked Shame he didnt say what the text beside the boxes he ticked said.
    Jul 2014
    Perth
    Yeah it tried the settings reset as mentioned above but still no luck. Does not seem to be much info around on it. Hoping maps disc will revive it, but still weird it went from OK to not OK with nothing being done to it
    Jul 2014
    Perth
    So far I have tried installing new maps, a firmware update followed by maps and then pulled out the unit and tested with a new GPS antenna. All to no avail, all that I get is no fix on the satellite and the screen GPS showing me as being in Europe.
    Has anyone heard if the units just losing the satellite part if their functionality? The car is a 2011 so just out of warranty, do you think Skoda will still look at it without charging an arm or leg.
    Unless someone can suggest something I have not tried?
    Wonder if its got the Regensburg syndrome
    Volkswagen RNS 510 Regensburg syndrome | my-gti.com
    Jul 2014
    Perth
    Ok might be a bit of a hike...Thought I'd ask just in case.
