Results 1 to 4 of 4
Thread: speakers too large for rear door, mount options ?
    Mar 2009
    Hi all,
    the 6.5inch subbys I got (I like a little noise, not a lot and don't want to lose boot space with subby boxes) are a little too big for the holes on the rear doors.
    I've grabbed some mdf spacers and cut and sanded them down last night so they fit in the holes. the only issue I have is the screw holes on the speaker plate don't match up with the screw holes in the door (they are a further out then the door mould holes).
    do I screw the mdf spacer into the existing holes and then use smaller screws to attach the speaker to the mdf spacer ?
    or drill a hole in the spacer and try and do a dodgy angle to fit the screws into the original holes ?
    thanks in advance.
    Jan 2009
    brisneyland
    Quote Originally Posted by diveboy View Post
    Yep.
    Which subs are you running? How much power are they getting? Are you doing anything else (deadening etc) to the doors?
    Very interested to hear about how they go.
    "One art please!" --->http://benno.redbubble.com
    Mar 2009
    using the response 6.5inch sub woofer from jay car
    Specifications
    • Nominal impedance:8 ohms
    • Power nominal: 60WRMS
    • Frequency response: 44Hz - 7kHz
    • Sensitivity: 89dB (1W@1m)
    • Qms: 2.02
    • Qes:0.567
    • Qts: 0.443
    • Fs: 49.52Hz
    Dimensions:
    • A= 178
    • B= 168
    • C= 145
    • D= 77
    currently have an old sony 220 watt amp from 7 years ago driving them, will upgrade to a different amp if I get them mounted and they sound good.
    Mar 2009
    best laid plans, still too freakin big.
    but just getting them in the doors, nice sound, will need to dynamat the doors I think, bit of rattle.
    as the coyote would say, back to the ole drawing board.
    I think google will be my friend tonight.
