Results 1 to 10 of 17
Thread: VW Passat MY13 RVC not working
    Sunshine coast
    My RVC stopped working, with no communication with the rear control unit. I finally got time to get it out, and it has a bit of corrosion. One of the pins on the connector is bent as well, I belive due to corrosion. Not sure how smart it was to locate this unit below the boot side pocket. I don't think there's a way to repair this pin, it can be seen bent in one of the photos?
    I've seen new control units are about $400+, so will try to get a new one from the wreckers.
    VW Passat MY13 RVC not working-pxl_20210322_041232182-jpg VW Passat MY13 RVC not working-pxl_20210322_041244236-jpg VW Passat MY13 RVC not working-pxl_20210322_041614577-jpg VW Passat MY13 RVC not working-pxl_20210322_043901106-jpg
    132TSI Tiguan Allspace
    Can't say I've ever seen one of those get water damaged.
    Might want to check where the water ingress is coming from.
    Just get one on ebay or from a wrecker.
    Sunshine coast
    I think it must have been a bottle in the side pocket above it that has leaked. A friendly forum member is sending me a different unit to test. It's a version H08 instead of H11, not sure if it will be any difference.
    Sunshine coast
    I've managed to source a new module from a wrecker. I'm still getting the "rear view camera system is not available at present" though, so I'm wondering if the camera is not receiving any power. I'd assume that the white cable pair connected to the second connector for the camera (which has a red and blue wire) should supply 12v to the camera when the car is in reverse? I don't see any voltage across these at all, so I'm wondering if there is a fuse somewhere which is blown.
    VW Passat MY13 RVC not working-pxl_20210414_074312084-jpg
    Sunshine coast
    Tried to clear fault codes, I'm now getting fault 01043 controle module; incorrect software version. I believe this might be because I'm using a module from a Tiguan. It has coding 0020010, but it should be 0020007 for a passat wagon. When I try to change it, I get an Error 31: request out of range. I tried using security access code 22351, but it seems to work for adaptation only.
    What's the software version on the RVC module?
    Sunshine coast
    rev H13
    Had to shorten the scan to get inside the 10k size limit.
    Code:
    Friday,16,April,2021,04:39:40:47231
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 21.3.0.0 (x64)
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: WVWZZZ3CZDE0*****   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
              56 61 62 6C 6D 72 77
    VIN: WVWZZZ3CZDE0*****   Mileage: 231020km-143549miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
       Component: J533  Gateway H40 1632
       Revision:   H40       Serial number: 170612F2000410
       Coding: 462007
       Shop #: WSC 05314 000 00000
       VCID: 41A79849D831B5838C-8014
    No fault code found.
    Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
       Part No SW: 1T0 035 680 L    HW: 1T0 035 680 D
       Component: RNS-MID       H70 5238
       Revision: AB001001    Serial number: VWZ6Z7M6168141
       Coding: 00000400000000A00011
       Shop #: WSC 05314 123 12345
       VCID: 3753F69186F5FB3332-8062
       Subsystem 1 - Part No: 7L6 919 859 G
       Component: AUNZ V8  8207
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    KSG PQ47 ELV 045 0634
       Revision: 00045000    Serial number: VWZCZ000000000
       Coding: 00900A00D2830E763404941570085F0B005801
       Shop #: WSC 40139 959 99896
       VCID: 76CD3B95017F423BE9-8022
       Subsystem 1 - Component:   Sounder n.mounted
       Subsystem 2 - Component:       NGS n.mounted
       Subsystem 3 - Component:      IRUE n.mounted
    Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 K
       Component: EZE_2         H40 1632
       Coding: 00000008
       VCID: 6FC30EF1BE2573F32A-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
    Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
    Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
       Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
       Component: J772__Rearview      0030
       Revision: 00H13000    Serial number: 525PA8-J484094
       Coding: 0020010
       Shop #: WSC 01324 011 00200
       VCID: 2D7FD4F9B4A941E358-8078
    2 Faults Found:
    01043 - Control Module; Incorrect Software Version
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 71
                        Time Indication: 0
    02203 - Audio / Video Input 1
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 71
                        Mileage: 231027 km
                        Time Indication: 0
                        Date: 2015.09.07
                        Time: 13:37:31
                 Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 K    HW: 3C9 827 383 K
       Component: J605  HECKDECKEL    0830
       Revision: 00H52001
       VCID: 3957F0A970E1ED43C4-806C
       Subsystem 1 - Part No: 3C9 827 384 K
       Component: J756  HECKDECKEL    0830
       Subsystem 2 - Serial number: 1200H52001001B0003ˇ
    Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007662941390
       Coding: 0201000000010101
       Shop #: WSC 00015 115 12345
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002_VW25.rod
       VCID: 3957F0A9B8E1ED43C4-806C
    End-------------------------(Elapsed Time: 02:46)--------------------------
    Sunshine coast
    I've seen quite a few people having issues coding the j772 module, so I guess it might need something else than vag-com?
    You have a Tiguan RVC module, not Passat. That's why it's reporting incorrect software.
    Sunshine coast
    Yes I tried changing the coding to 0020007 for passat, but it won't accept it, giving error 31: out of range.
