Results 1 to 10 of 13
Thread: RNS510 with Fiscon Kufatec Bluetooth but no working microphone
    Jun 2014
    Hi,
    Have had a Mk6 GTI for over a year now which came with Fiscon Kufatec Bluetooth unit installed. It was working fine the last year and all of a sudden it stopped working. The car has been sitting dormant for over a week and perhaps was low on battery but don't think that would have contributed to this.
    Anyone know who could have a look to get this fixed (Sydney based) or thoughts on how to address this issue?
    Apr 2015
    Brsbane QLD Australia
    Can you find the control module. If so dsconnect it and reconnect. See if it works then mate.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
    Mindarie, Perth (WA)
    Quote Originally Posted by Darkhorse Developments View Post
    ^^^this.
    Try and start your search by looking under the driver's seat. After that, try passenger's seat, and finally.....if not there, it'll be 'hidden' behind the dash/Head Unit.
    Jun 2014
    Nothing under drivers or passenger. will have to suck up the courage to take out the head unit, nail biting for a noob like me!
    Dec 2009
    Kew, VIC
    Quote Originally Posted by luongie View Post
    Nothing to it, mate — a 5 minute job.
    With small screwdriver or other suitable device, prise out the RNS510 surround — it’s all on clips — and remove the 4 Torx 20 screws holding the head unit, which will now slide out far enough to allow hand access.
    There's plenty of slack on the wiring to let you work behind the unit.
    Jun 2014
    Awesome. Will give it a crack first, was fearing once taken out there would be other issues. Thanks everyone for your help!
    old credit card etc is also handy to remove the trim surrounding the head unit
    Jun 2014
    Ok. Thanks for all the advice. It's worked! Used an old plastic trimming tool I had from an old car seat cover set to pry open the cover and low and behold the Bluetooth unit was hidden behind the head unit. Disconnected the plug and reconnected again to the Bluetooth control unit . Then just had to pair the phone again and it works! Very please with myself and thankful for the help. Cheers!
    Jun 2014
    [/IMG]
    Apr 2015
    Good work mate! If it keeps happening hit me up for a vw 9w7 BT kit!
