Results 1 to 9 of 9
Thread: Project EOS
    Aug 2011
    Canberra
    Cool Project EOS
    So, having had my baby for about 18 months now, it's time for me to start thinking about modding her...
    The current plan is to get to stage 2+, with a few other handling mods, and, if I win the lotto, do an AWD conversion...
    As my Eos is based on the Mk5 Platform, and has the GTI's BWA engine, most parts are plentiful, so that will definitely help.
    Step 1. Change the AFM to turbo pipe (wish I could find this one - Samco Silicone Intake Pipe)
    Step 2. Upgraded HPFP (Considering APR, IE, CS, AT and VIS, but will probably get the APR as it suits me better)
    Step 3. Rear Sway Bar Upgrade (Probably 3C0511409E 21.7mm x 3.6mm from a Passat, but I need to check which I have now)
    Step 4. High Flow Filter (Still Paper Style though)
    Step 5. Dump Pipe (Probably Empire Performance with 200cel Cat, but possibly APR as it give a discount on stage 2)
    Step 5.5. 'Straight' to APR Stage 2+ done at the same time as step 5
    Step 6. New Shocks (Probably Bilstein B6's)
    Step 7. DO88 Intercooler
    Step 8. Front Alloy lower control arms / knuckles (From Passat)
    Step 9. AWD Conversion (Mk5 R32, Mk6 Golf R, or Audi Gen2 TT as donor)
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
    Aug 2011
    Canberra
    HPFP Options...
    APR - APR 2.0T FSI High Pressure Fuel Pump (HPFP)
    Good - Stock style retainer, uprated spring (reduces 'bounce' wear), single diameter piston, ~40% more fuel (lower than others, but causes less wear), great support
    Bad - Most expensive
    Integrated Engineering - IE High Pressure Fuel Pump (HPFP) Upgrade Kit for VW & Audi 2.0T FSI & 4.2L FSI Engines
    Good - Single diameter piston
    Neutral - Decent quality, 'OK' cost, ~50% more fuel
    Bad - Collet style retainer, stock spring, uncommon
    CorkSport - CORKSPORT MZR DISI MAX Flow Fuel Pump Internals | CorkSport Mazdaspeed HPFP
    Bad - Stepped diameter piston, uncommon on VW's
    AutoTech - Autotech High Volume Fuel Pump Upgrade Kit early 2.0T FSI + MAZDASPEED 3 6 - MKV (2006-09) - Golf/GTI/Rabbit
    Good - Most common, cheapest
    Neutral - Decent quality, ~50% more fuel
    Bad - Collet style retainer, stock spring, stepped piston, ~50% more fuel
    VIS Motorsport - 2.0 TFSI EA113 4.2/5.2 FSI/MAZDASPEED | Romania | Vis motorsport | vismotorsport
    Good - 'Cheap' (Can give below recommended price offers on their eBay listings)
    Neutral - Stock Retainer, ~50% more fuel ('small' option)
    Bad - "Lowest" quality, stock spring, stepped piston, ~70% more fuel ('large' option)
    Aug 2011
    Canberra
    Forgot to mention, I have already installed a GFB DV+ Diverter Valve Upgrade Kit.
    This is a great bit of gear, and functions significantly better than stock, with the added bonus of being cheaper than a stock unit.
    Whilst you do need a stock unit with a working solenoid, my DV had been intermittently sticking open, causing low boost issues, but was still upgradable.
    Aug 2011
    Canberra
    Hmmm, seems like the Bilstein B12 Pro Kit may be the way to go...
    Seems to be a similar ride height to what I'm sitting at now on the stock springs.
    Need to keep an eye open for them on sale now.
    イシカワエンジニアリング スタッフブログ:EOS 2.0T * BILSTEIN B12 PRO-KIT
    Aug 2011
    Canberra
    Nice but no MK1.
    I will regret selling the Cabby till the day I get another...
    Now stop rubbing salt into the wound Paul.
    Still, I wouldn't have this lovely car without selling it, so there is that.
    Aug 2011
    Canberra
    So, here's an interesting one...
    I gave my girl an oil and filter change on the weekend, and, it seems that she is now running up to 1/2 a litre per 100 more efficiently...
    Old oil / filter was Penrite Enviro+ 5w30 with a Ryco filter.
    New oil / filter is Castrol Edge LL 5w30 with a Hengst filter.
    Still, very nice to be in the low 7's on the way to work this week, compared to high 7's last week.
    And I don't remember that same change last time...
    Nov 2019
    Perth
    Have you gone Stage 1? If so, how was it?
    Aug 2011
    Canberra
    Yes I’ve done stage 1 APR.
    Yes it’s better.
    Makes it feel much closer to a gti in performance.
    Definitely how it should of come.
    I want to go stage 2, but the cost is putting me off...
