Results 11 to 20 of 30
Thread: Fuel type is it 95 or 98?
    Nov 2007
    Quote Originally Posted by chrisb123 View Post
    If they recommend 95 as minimum then 95 is just fine, then again with my luck the engine will explode next week and none of this will matter. I just spent half the price of the car getting the transmission fixed and I only bought it this month
    Actually, they don't recommend 95, they recommend 98.
    Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP (mods are underway ) 2018 MY18 Golf 110TSI Trendline manual White (with mods now 150TSI) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 10 Previous VWs and some others ...
    Feb 2021
    OK but why does the fuel lid say to use 95? Back to the original post it is misleading and conflicting, most people will just use what the fuel lid says
    If your fuel lid has a little 95 and a big 98 then it means that you can use 95 in an emergency until you can fill up with 98.
    Feb 2021
    What if it only says 95 and no mention of 98 at all?
    Pacific Paradise QLD
    Well you would use what it says wouldnt you or you can use 98 if you have too much money
    Feb 2021
    But the manual says 98 with no mention of 95
    VW has just confirmed my 170k km car is using the old cam chain tensioner, so I guess we can close this thread cause the car (knowing my unlucky streak with this car) that it will explode as the tow truck driver drives it onto his truck
    Yes the cam chain tensioner was updated from around mid-2012 onwards, so any car built before this time has the old tensioner. I had to replace it on my Mk6 GTI which was a 2010 model too.
    2017 Ford Fiesta ST
    Well put 98 in it then
    Feb 2021
    How much did that cost to replace?
    It was about $1200 (done at local Audi dealership) and included the following:
    - new upgraded tensioner
    - multiple chain guides
    - new timing case cover (old one gets damaged when removing so new one needs to be fitted)
    - new dipstick tube (made of plastic and got damaged when removing timing case etc
    - sealant / new bolts etc for timing case cover.
    - Oil change (i provided the oil - the oil needs to be drained to do this job)
    I was advised at the time that the timing chain itself did not need replacing, but always wished I had done it. For an extra $250-300 you may as well do the timing chain at the same time.
    My car had about 58,000km on it at the time and was about 5 years old.
    2017 Ford Fiesta ST
