VW Touareg - rough start- 2017 V6 Tdi
Hi There,
I have noticed an issue with my 2017 TDI V6 Touareg at start-up, which has a very rough idle and started to shake.
I have only started noticing this at a cold start. I scanned the car without any indications or clues from the sensor readings. Could someone point me in the right direction regarding what I should look at?
Please advise.
Scan below
Friday,10,November,2023,05:17:34:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 23.3.1.0
Data version: 20230421 DS346.2
Ross-Tech: Home
Mileage: 182587km-113454mi Repair Order: 000
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69
6C 6D 72
Mileage: 182587km-113454miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
- You may not post replies
- You may not edit your posts
Forum Rules
