Results 1 to 10 of 20
Thread: Rusted Brakes, what to do?
    Mar 2015
    Hey all,
    I've been wanting to paint my calipers lately, but jsut the other day, I've noticed that there
    is a **** load of rust all over my rear brakes.
    Google search tells me this is normal, and comes off when you apply brakes, however that does not seem to be the case for me and I definately want to remove this as it's quite an eye-sore.
    It's a bit late, so I'll update with actual photos tomorrow, but for now, it's something similar to this:
    http://www.foreignaffairs.us/gallery...and%20Rust.JPG
    Thanks for help, will update tomorrow
    TL;DR
    Brake discs are rusty, how to restore to normal/maintain it?
    **EDIT: ADDED PHOTOS**
    Attached Thumbnails Attached Thumbnails Rusted Brakes, what to do?-2015-06-24-14-17-12-jpg
    Oct 2014
    You'll probably need to get the rotors machined or polished mate
    Mar 2015
    Quote Originally Posted by Hiken View Post
    That's annoying... Since I Recently purchased the car, and the RWC included having the rear brakes changed, I have a warranty on the check, would I be able to claim warranty on this?
    May 2013
    Mine will do that overnight... It goes away when you drive the car, right?
    The rust is because of the material the rotors are made of... No big deal
    Sent from my GT-I9505 using Tapatalk
    Pacific Paradise QLD
    Go for a drive put brakes on Problem solved. Dont take it out in the rain or wash it and it wont happen again. Mine go like that when I wash it.
    Oct 2010
    Melbourne, VIC
    Brake harder
    Resident grumpy old fart
    Mar 2015
    Just added photos to main post.
    I took it for a quick drive and did some braking but its still there, albeit maybe a little less.
    can i take a microfibre cloth or something and try rub it with water or something?
    You worry too much go for a longer drive with more corners needing a bit more braking Every time they get wet they will do that.
    Erskineville, NSW
    The rusty part appears to be the hub, not the friction face of the rotor itself. You can wire brush the rust off & paint it at the same time you do your calipers
    Mar 2015
    So it's safe to paint that bit where the rust is? I don't wanna paint it and make my brakes not work properly or something
