Originally Posted by
Jmac
Ah yeah sounds good ill look into that mate. Loads of parent metal to play with. At the end of the day if all else fails i will use a tried and tested method i used on aircraft structures - Oversize bush couple of thou oversize then use liquid nitrogen to freeze and insert bush. So really having that there is tons of parent metal i could fit a say 22mm freeze plug giving you a fresh chassis rail so to speak then you can take it back to 17 0r 19mm worst comes to worst hey. Ill be looking at the keyserts 1st
Cheers again
Jmac
