Intro and a few q's
Evening all,
Six months ago I bought my daughter's '95 Cordoba (140K) with a view to fixing it up as a runaround for my wife.
I've mucked around with cars, on and off, for over 40 years (although the last euro-car I worked on was my Fiat 125 in 1978 ) and have a reasonable workshop and tools.
There's a bit of history to this car but to condense it to manageable proportions:-
It was overheated ("got a bit hot" according to my daughter) and as a result ended up with coolant in the sump.
A month or so prior to that, the auto transmission cooler corroded internally and ended up with coolant in the transmission case.
The sensor/switch for the thermo fans is faulty which would probably explain the engine overheating.
The air-con pump is faulty (air-con doesn't work) according to an auto electrician my daughter had it to just prior to the transmission probs.
I've finally got around to having a look at it and pulled the head off it today. The gasket "looks" ok. I'm guessing the head is cracked but in any event I'll take it and the gasket down to the local head place tomorrow.
With regard to the transmission oil cooler - after hunting around locally for a replacement I ended up fitting an aftermarket radiator type cooler which bypasses the radiator. This appears to work well and I was assured by the VW dealer's workshop foreman there's no problem with doing that modification.
The problem with the transmission (after half a dozen flushes here at home and a full flush and filter replacement at the local auto trans guy) is that it won't change up 1-2, 2-3, 3-4 unless it's doing around 4000rpm. If it's driven normally it will just stay in 1st (until it's doing 4K rpm).
From memory it changes down ok.
Trans guy reckons it could be a solenoid but if anyone has a suggestion, I'm all ears.
I guess I'll replace the air-con pump with a second hand one so that shouldn't be a huge production.
So, that's the condensed version.
I've got a Haynes manual for the Seat but it's a very complex manual to work by.... particularly with greasy hands.... "do this but refer to section 4a first" which then takes you to 5b and then onto 3c, or whatever, lol.
Thanks for reading this far and if anyone has questions/advice/hints please speak up.
I'm old enough to realise there's still a lot to learn
- You may not post replies
- You may not edit your posts
Forum Rules
