Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Noisy engine or is that just me
    Jul 2005
    That'll probably be the dual mass flywheel if it changes with clutch pedal.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    brisbane
    Or maybe it was changed for a single mass by the previous owner?
    Jun 2018
    St Lucia
    Quote Originally Posted by yumenuu View Post
    Hey, just wanted to check if you ever got this resolved and if so what was the cause of it?
    I've just bought a second hand scirocco r myself and am having a similar issue of a rattle noise that stops when I push the clutch in.
    Hey mate, mine is a dsg and I did some research on the net and found that the hpfp cam follower adds to the noise. Got that replaced and it did quite the noise but it's still there. Apparently, that's normal for these engines.
    Sent from my Pixel 3 XL using Tapatalk
    They’re definitely not a quiet engine but as above recommend replacing the fuel pump cam follower as preventative measure.
    Jan 2019
    Can you post up a short video to demonstrate the sound? How many km's on the engine?
    The engine in the Rocco R has a timing belt, but on the other side of the engine, the 2x camshafts are joined by a chain and tensioner, so its possible something isn't right there.
    If the car has a few km's under its belt (say 60k or more) it might be a good idea to change the cam follower on the HPFP which is about a $80 part (its a wear item, so its designed to wear out over time). If you are somewhat handy this is a DIY job. Cam follower - 06D109309C – V-tech Australia | Engineered Performance
    Thanks for the tip
    Just had my 60k service and after
    A week I’ve got odd noises !
    I’ll be changing the cam shortly
    Sent from my iPhone using Tapatalk Pro
    Jan 2019
    Quote Originally Posted by Firstof3 View Post
    Thanks for the tip
    Ha
    Still haven’t found a workshop that will do the HIGJ Pressure Fuel Pump cam follower for less than $500
    But I did discover my bonnet strut pivot end has lost its rubber grommet and rattles !
    Anyone else got a pic of what the bonnet strut pivot Gromet should look like ?
    Ha
    Its a 20 minute job. Just do it yourself - its pretty basic.
    2017 Ford Fiesta ST
    Jan 2019
    Yes I see a few posts saying easy.
    As I understand it you remove the lines and the pump and replace the follower. Seems straight forward.
    Of course that means a gasket and making sure the fuel lines are depressurised and then bled free of air.
    What could possibly go wrong with a HIGH pressure fuel pump ?
    DOES ANY ONE HAVE Actual experience with this. I’d love to know what to buy ahead of doing it. I really don’t want to get stuck with a leaky gasket.
    I already learnt that just ignoring the little o ring on the dipstick has dire consequences.
    TIA
    Follow the first 12 steps in the DIY I did a few years back. I never changed the o ring as my car only had about 10,000km on it at the time, but it would probably be a good idea to replace the o ring now that these cars are getting older. Autotech HPFP Upgrade full DIY guide with pics
    VAGParts in Sydney would be able to source you the genuine o ring. Volkswagen Scirocco Parts, VW Scirocco Car & Auto Parts
    – VAGPARTS Australia
    2017 Ford Fiesta ST
    Feb 2015
    Sydney, Australia.
    Quote Originally Posted by Bops View Post
    sounds like ur suffering from the ea888 truck sound.. what oil u using CASTROL OEM?
