Results 1 to 10 of 20
Thread: VR6 Oil Catch Can?
    Dec 2006
    Kilsyth, VIC
    VR6 Oil Catch Can?
    At the moment the vent from my crank goes direct to the intake, I'm also chewing through a little oil and since there are no valves in this direct line I reckon it's a good bet that a solid vacuum on the intake from the crank case isn't helping.
    So... I have been looking at a couple of options.
    The cheapest is to just put a little filter on the crank vent at let it vent to the atmosphere... cheap, effective... maybe not legal (and oil may drip on things)
    Plan B. Catch can from the crank with the other end of the line still running to the intake. Probably the most legal option. What I don't know is how the can works?? Does it turn the vapour into liquid or am I just adding extra space between the crank case and the intake??
    Plan C. Catch can from the crank with a filter to vent to the atmosphere.
    So who has done what? What's legal? Whats possible? Whats recommended?
    Jul 2007
    Rowville Melbourne
    i would also like to know...
    mine uses probably about a litre every....5-6 thousand km.
    ive heard a few ppl say euro cars use a bit, but my old GL didnt use a drop in two years. are VR's supposed to? i dont know.
    -steve
    Point Cook, Vic
    Quote Originally Posted by Shteifen View Post
    -steve
    If you drive her hard thats about right.
    Im eventually gonna put a catch can on my VR6. Ive cleaned up my throttle body a few times and its amazing how dirty it can get.
    FOLLOW US ON FACEBOOK
    Jul 2007
    Rowville Melbourne
    ya i guy i work with reckons its had the crap thrashed out of it. i tend to believe him in the morning, cos when i start driving to work the gearbox wines a bit for maybe a hundred metres or so and goes away.
    would be nice not to have to check oil every few weeks
    -steve
    Jul 2007
    Rowville Melbourne
    do yo know if anyone sells a catch can kit or somethin? or would you just ahve to improvise?
    -stve
    Dec 2006
    Kilsyth, VIC
    They are a pretty generic part that you pretty much make up the connections as you go. Shouldn't be too hard...
    I'll be looking into it over Christmas while I'm off work, but to be honest, the latest thinking was with only driving around 10,000 km a year, it's not a lot of oil to use up, and oil is cheap as... although as Tim has said, less oil through the throttle body will never be a bad thing
    We will see.
    Jun 2007
    Eastern Suburbs Melbourne
    If it was a mk 1, this is what I'd do
    Cheers to Tim for pics/idea.
    Cheap, easy and it works. Keeps the crap from coming back into the intake. Just make sure you block off where the factory breather goes back into the intake.
    Hope this helps.
    i like volkswagens
    Dec 2006
    Kilsyth, VIC
    Hope this helps.
    Nice work Do you actually catch much oil in that? Would have thought the vapourised oil would just go through the filter.
    The only issue I have with that solution is the fumes it could cause. Sames goes even if you get a propper baffled catch can and vent to the atmosphere, although it should be reduced over what you have since the baffles should 'filter' the oil out somewhat.
    Plan B is to plumb back into the intake after the catch can to remove the fume problem entirely and still be as close to legal as possible.
    Plan B sounds like the better option and is no more expensive than not plumbing it back since it's either get a filter or the appropriate pipe.
    Jun 2007
    I can't see why plan B wouldn't work. but depending on how the pipes are set up, I geuss that you might still run the ristk of getting oil back through the intake.
    With the powerade bottle, it's basically just a cheap catch can. probably not legal in NSW, isn't here really. But it works. oil goes in the bottle, fumes out the top, throught the autobarn special filter. Don't think there's an issue with fumes in the cabin, I don't have any such issues in the audi, which has this setup. I don't use oil really, so my bottle is empty basically, bar some residue.
    i like volkswagens
    Dec 2006
    Kilsyth, VIC
    I think I use more oil because the intake it just sucking at the crank, your solution (as with any catch can not plumbed back) it's only excess pressure, not a vacuum pulling the fumes out. I assume the valve that is supposed to be in there is such that the normal intake vacuum isn't enough to open the valve, but when the crank gets to a certain pressure point it opens. The question is will a baffled catch can *reduce* the suck through considerably while still allowing for pressure release?
    I'll have to experiment a little when I get some parts to play with.
