Is it when you have the indicators on... and is in time?
Mine does that when the lights + indicators are on sometimes. The auto elec seems to think it might be like alot of BMW's with a sensitive voltage sensor, basically it senses a drop when the light blinks, so raises the revs, voltage goes up, the lights blinks off, voltage drop so so do revs... repeat...
does that make sense?
Everything seems to work fine and there is no dip in lights if I manually raise the revs so it sounds like he might be onto something.
Personally I think it might also be a battery in need of a good charge that doesn't help the situation too.
