Results 1 to 10 of 15
Thread: Pulling badges off
    Jan 2008
    Newcastle, NSW
    Pulling badges off
    Hey all.
    I got the "VR6" off the front.
    Today I want to pull the fornt and rear VW and also the "Golf/VR6" off the rear.
    I don't have tools (the tools go with the old boy to work) to pull the front and rear emblems off. Is there an easy method?
    Also, when pulling the golf/VR6 off the back, i went to my sisters to get her hair dryer, and also bought some turps. Will the turps be good enough to get the residue off?
    Ta.
    Jan 2008
    Newcastle, NSW
    And I couldn't be bothered searching through countless Vortex threads all about badgless etc...apologies for that.
    Oakleigh VIC
    Fishing line and turps usually gets the stuck on badges off. Heat helps soften the adhesive too.
    Pete
    Dec 2007
    Ermington, Sydney
    Ray made a post on here a while back about getting the 'golf' bit off (where your golf VR6 bit is) and his worked a treat. Can't quite remember how he did it but he also did my rear VW badge for me....he just heated it up and carefully pried it off with a taped-up flathead
    Jan 2008
    Newcastle, NSW
    Yeah i got the golf/VR6 bit worked out cheers. Havent done it yet but i know how to tackle it.
    Didnt know about the F/R VW though. So i can get the back one off now...just the front one to work out now..
    Nov 2006
    Central Coast, NSW
    You can do the rear VW the same way as the model badge.
    heat up the badge with a hair dryer enough for the silicon/glue to turn gooey and then pry it off with a taped up flathead screwdriver.
    the front VW badge clips into the grill so you just take the front grill of and poke the cadge out from the back.
    hope that helps.
    Jan 2008
    Newcastle, NSW
    thanks lachie...need to wait till about 7 to get the grill off then
    Nov 2008
    Arundel QLD
    eucaliptys oil is good for removing glue residue
    Mindarie, Perth (WA)
    Dental floss
    Sep 2006
    West Sydney
    Quote Originally Posted by schoona View Post
    You mean the VW badge on the grille? It'll be easier to take the grille off first so you gain easy access to the tabs that hold the VW badge.
