Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Paul's VR6
    I dunno about the spacer under the bearing.
    But otherwise should have a flat looking nut to hold the bush/bearing to the coil. Then you have a normal but to hold the whole assembly to the strut tower/body
    May 2010
    Melbourne. Victoria
    Thanks Dylan.
    I Found a flat looking nut in the parts from ECS have added that in
    Without the spacer the nut runs out of thread and the bearing and the plate that sits above the spring are all loose.
    With the spacer it’s all tight, the top plate all held in place and as I tighten the nut I get some compression in the spring
    Feels like that’s right now I just don’t know how far to tighten it
    See photo below
    Paul's VR6-coilover-setup-jpg
    1996 Golf Mk3 VR6
    2006 Golf Mk5 2.0 TDI
    Very good.
    I had the torque settings on a piece of paper that came with my refresh kit. Otherwise I can pull the Bentley manual out and have a look
    In the past I've just done it as tight as possible by hand as I'm normally fighting it with inadequate tools
    May 2010
    Melbourne. Victoria
    Awesome and thanks. I have a Bentley manual so will see what I can find.
    Messed about with rears too, couple of shots below, seems more straight forward.
    Bottom plate and sleeve
    Paul's VR6-rear-1-jpg
    Then all the other bits from ecs kit
    Paul's VR6-rear-coil-2-jpg
    I also ordered a strut tool from a local tool supplier, 21mm version should arrive tomorrow.
    Hoping my 7mm Allen key is long enough.
    1996 Golf Mk3 VR6
    May 2010
    Melbourne. Victoria
    The 21mm strut socket arrived today from ozwidetools. Fair bit cheaper than ordering from the States let’s see how it holds up.
    It’s 1/2 inch drive so fits all my tools hoping it will be ok
    Paul's VR6-strut-nut-jpg guy ru
    1996 Golf Mk3 VR6
    May 2010
    Melbourne. Victoria
    Finally got the coilovers in
    Have had a few distractions, other things to take care of over the last few months but finally got some time over the last 2 days to get the coilovers fitted to the car. Was easier than i thought, did buy some stands, a trolley jack and an impact wrench so had no excuses and wanted to make sure I didn't drop the car or do anything silly. So far so good, lets see how they go. Some photos below on the outcome as well as few steps. As far as driving goes its a harsher ride however it feels very solid, cornering so much better. Next step is to get a wheel alignment done.
    Here is the before shot with very high ride height
    Paul's VR6-golf-vr6-2018-jpg
    And here is the new look with the coilovers installed
    Paul's VR6-img_3872-jpg
    Paul's VR6-img_3871-jpg
    Paul's VR6-img_3870-jpg
    And a couple of progress shots from the day, didn't take a lot was trying to stay focused, was a bit hot outside
    Paul's VR6-img_3852-jpg
    Paul's VR6-img_3857-jpg
    Paul's VR6-img_3858-jpg
    1996 Golf Mk3 VR6
    Nov 2015
    Nice work, looks good with the new stance.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    May 2010
    Melbourne. Victoria
    Thanks
    I got a wheel alignment done yesterday and that’s made a big difference the the ride. Will do a bit more driving on the weekend.
    1996 Golf Mk3 VR6
    Mar 2020
    Auckland, New Zealand
    Awesome job mate. Any more updates since then? I am doing the same with mine over the ditch in New Zealand. I have a full spec 3 door vr. There is a thread for mine on VASK nz
