Results 1 to 5 of 5
Thread: Vr6 ecu
    Jun 2011
    Vr6 ecu
    Without this turning into a cock fight.
    What stops me from using a US ECU in my car? Assuming that the ECU I purchase is obd1, coilpack and has immobilizer bypass.
    I don't see vw running a different connector for the wiring, or anything silly like that.
    Reason being is I want to get 288 cams and don't want to run standalone at this point in time.
    "I only post on Facebook if I know i am going to get likes" - M
    Aug 2008
    Rowville, VIC
    Vr6 ecu
    the tune for different fuel?
    metric vs imperial??
    stabbing in the dark...
    Apr 2006
    VW Race HQ - Sydney
    Probably the plugs , there are different mk3 VR6 ecu's as well that wont work cause the plugs dont work . I guess it could work if you got a harness with it .
    Bug_racer supports the rebellion of the euro revolution
    Aug 2007
    How much can you get the ECU and tune for, If its cheap it is worth a try
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
    Jul 2009
    Vr6 ecu
    Bump I want to know as well
    '94 3dr vr6
