Any cool mk3 happening's been dry around this section.
Printable View
Well the CL decides to start now and again....
How many Mk3's can we get at DOVW?
got my 404s and pro ride rack on, does that make me cool?
hopefully throw my basket and fairing on for extra street cred
Off to japan for 10 days, have big goals for the CC but we will see how much money I'll have left after. Bags and Rims would be nice but it still needs a few more bits to be the reliable daily.
I used zip ties to keep my fog light is. Does that make me cool? (No the fogs arnt wired up yet)
http://www.vwwatercooled.com.au/foru...54179cc1-1.jpg
Sent from my SM-G900I using Tapatalk
My co-worker replaced her Golf Cabriolet with a MK1 Ford Territory. So now I don't even see that around anymore.
Thermo fans stopped working in my mk3 cabby today.
Could it be a fuse or the fan motor?
When I turn one fan by hand the other turns with it.
Not sure what I should test first.
Sent from my GT-I9506 using Tapatalk
Can anyone please please please help?
Think I have a blockage in the motor.
So far I've tested the fans with a jumper from the battery and both high and low speed work.
I've replaced the temp sensor in the radiator, replaced thermostat, replaced fan relay under the expansion tank, back flushed the radiator with a garden hose.
Have new coolant and no leaks.
Tonight I found the two small hoses that live under the throttle body were completely blocked.
Removed them, cleaned them out and refitted.
Also replaced the coolant temp sensor on the top radiator hose.
Still can't get the fans to kick in.
If the coolant galleries in the motor are blocked, how do I clean them out? Is radiator flush enough?
Top and botom radiator hoses run hot.
I'm totally mystified!
Hoping someone on here can point me in the right direction.
Thankyou!
FIXED IT!!!!!!!
When testing the fan switch I could only get 1 speed. Turn the ignition on and 2 speeds worked.
This meant that the problem was either fan switch or the switch was not submerged in coolant.
Pulled out the air release valve next to the coolant sensor and it emptied the expansion tank.
Topped it up and took her for a fang and she never went above 90 degrees.
Pulled into my driveway and popped the bonnet and soon enough the fans came on!
Job done. The problem all along was a blockage in the 2 small hoses that go to and from the throttle body and air stuck in the cooling system.
So happy it's sorted and can drive her again. :)
Anyone still on here?
I have a knock coming from my front left when I turn hard/sharp left or right in our cabby.
It generally happens every time I pull out of the drive way at low speed but may also occur at high speed.
Suspect steering related but guess it could be a CV, control arm bushes or sway bar.
Anyone got a method for diagnosing?
Cheers!
