Awesome build!
Awesome build!
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
Got sent the wrong hubs for the rear took a little while to rectify the issue but the rears are now mostly complete. I need to get some shorter struts (MK1/Polo/Ibiza) as the car is so light in the back the shocks aren’t compressing.
I over measured the length of the rear beam arms - the wheel base has been increased by a fair amount. I had to clearance the rear bumper some more.
Now with the rear brakes fitted I was able to finish the brake lines off. Just need to grab some p-clamps the secure the braided line to the body.
I also grabbed some 4mm plate to make a few things. Firstly a mount for the shifter and staging brake. Will get the rear section folded and welded into roughly this location.
Pushed it out on to flat ground to assess the suspension situation. Really need to make up some side skirts now.
Can see the extent of wheelbase extension now.
Attempted to bleed brakes on the weekend. Found out that a lot of the connections leaked - I had my suspicions because of a crap flaring tool, but thought they would still be ok. I was wrong. So redid almost all of the flares.
Before
After
My initial tool didn’t give a good first ‘bubbling’ step, so was only a ‘single’ flare.
Photo less updates:
I then stripped out more wiring (headlights, taillights and anything else that wasn’t critical)
Put the dash back in, and removed the front front sway bar.
Chopped out some metal in the headlight area’s.
Test fitted some of the power steering lines, still need to figure out where I will mount the reservoir.
Fixed the crap wheel alignment.
Fitted the correct hub rings and lug nuts for the Honda rear end.
Also went through and started replacing the oem bolts with some light weight Porsche sourced alternatives
its electric power steering pump now yeah? any reason your not removing it completely?
It’s still hydraulic/OEM power steering at this point, later on I will go to electric.
Power steering delete sucked in the other car. With the locked diff and radials the car steers all over the place, would be very difficult to control with no assisted steering.
Very cool mate, the rear beam looks great.
Sent from my SM-G965F using Tapatalk
'89 VW Golf MK2 2dr VR6
'96 VW Golf Mk3 2dr
'02 VW Transporter SWB
