Few more bits and pieces done. Wotbox has been a little bit of a hassle; doesn’t want to work with the ECU. So not sure if I’ll be able to work around it not.
Reassembled the front crossmember and bumper mounts, put in the power steering pump and wired up, radiator fan wired up, fixed a split injector o ring i found out about this morning when I started it.
Fabricated front engine mount
Electric power steering pump hiding away
Terminated ends, switched power in the deutsch connector, that goes into the switch panel inside
Passenger side bumper mount and backside of fuel cell
Mismatched radiator hoses, but what was laying around!
All together
Annnnd, made these mirror deletes out of a sheet of carbon. Will be making a centre fascia/switch panel out of the same sheet.
Loving that subframe.
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
