Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: New Parts for the VR6
    Dec 2006
    Kilsyth, VIC
    Seems one of the CV boots are torn, since it can't be replaced for a couple of weeks anyway since I will be out of state I'm looking at ordering some new ones from German Auto Parts:
    http://www.germanautoparts.com/main.php
    As these things go... while your there you may as well get a few bits and pieces.
    Bushing kit, front control arm, polyurethane Complete kit for both front control arms. Stiffer than rubber bushings, sharpens steering response but transmits more road surface vibrations. Does not require spacer sleeves. 27.56
    Spark plug, NGK BKR5EKU 2-electrode copper plug. Currently used by VW in VR6 engines. 5.79
    Polyurethane bushing kit, rear upper shock mount Set of 4 bushings, two large and two small. Firmer than original rubber bushings. One kit required per car. 20.95
    Ignition wire set, high performance Includes 6 plug wires plus coil wire. Coil wire not required for models w/o distributor. Features original German Bremi connectors with correct resistance values and a 19 strand copper wire with dual layer silicone insulation. Limited lifetime warranty. 93.71
    Ignition wire removal tool Ignition wire removal tool - Removes ignition wire from spark plug without pulling on cable. Professional quality metal tool designed to last, does not break like plastic versions. This tool is essential to remove ignition wires without damaging them. 43.00
    Oil filter kit Original equipment. Includes oil filter element and seal ring. Filter element has plastic ends. 10.92
    Sealing washer, 14x20mm, copper Seal ring for oil drain plug. Should be replaced at each oil change. 0.11
    Expansion tank With built-in level sensor 43.58
    Cap, expansion tank Includes seal 7.50
    C.V. Boot kit. Includes new boot, circlips, grease, clamps, and axle nut. Outer. 17.09
    CV Boot kit, for 100mm (3.93 inch) diameter joint Inner. Left side. 16.54
    CV Boot kit, for 100mm (3.93 inch) diameter joint Inner. Right side. 17.64
    Total US$372.49 + Shipping (which should be around US$75)
    Total AU$421.73 + shipping or assuming shipping is right it's about AU$506.65 landed.
    Couple of questions for the more learned mechanics amoungst us.
    Although they are the only CV boots listed, are they the right ones?
    When it comes to the suspension bushings, I have these coilovers coming:
    http://www.germancarperformance.com/...ld-p-1139.html
    and this dome bearing kit:
    http://www.germancarperformance.com/...it-p-1155.html
    so do I actually need all the bushing I have listed?
    Lastly, I'm planning on putting the order through in the next 24 hours or so, so if anyone wants in on some parts to share shipping costs, be quick!
    Sep 2006
    Australia?
    Expansion tank? Please explain? I would also go for a Bushings kit but I don't know about the bumpiness wouldn't it be more?
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Mk3vr6 View Post
    You know where you put in your coolant into that clear bottle. It's going to be replaced very soon for two very good reasons:
    1. It's from a 2.slow
    2. It's black
    Ingnore the yellow bit, but see the tank:
    As for bumpiness... it's getting lower with the coilovers anyway... how much bumpier can those bushings make it??? Anyone with experience?
    Sep 2006
    Australia?
    That would be my concern, however I do want a new bottle I will send you the money PM me your bank details and I will send you it
    It would be nice to have a clean bottle lol.
    Dec 2006
    Kilsyth, VIC
    PM sent, anyone else want any parts from German Auto Parts?
    Dec 2006
    Kilsyth, VIC
    OK, last chance for anyone interested as I'm putting the order through today.
    New PM's heading out to Raymond and Steve with some details.
    Dec 2006
    Kilsyth, VIC
    Ordered! I'm now waiting for a confirmation of shipping costs.
    Code:
    Order Summary________________________________________
    3 @ 0.11 ech	Sealing washer, 14x20mm, copper Volkswagen Golf
    3 @ 10.92 ech	Oil filter kit Volkswagen Golf
    6 @ 5.79 ech	Spark plug, NGK BKR5EKU. Volkswagen Golf
    4 @ 20.95 ech	Polyurethane bushing kit, rear upper shock mount. Volkswagen Golf
    2 @ 2.21 ech	Nut, strut bearing retaining Volkswagen Golf
    1 @ 93.71 ech	Ignition wire set, high performance. Includes 6 plug wires plus coil wire. Coil wire not required for models w/o distributor. Volkswagen Golf
    2 @ 7.50 ech	Cap, expansion tank Volkswagen Golf
    2 @ 43.58 ech	Expansion tank Volkswagen Golf
    1 @ 27.56 ech	Bushing kit, front control arm, polyurethane Volkswagen Golf
    3 @ 35.00 ech	Strut bearing kit, heavy duty. Volkswagen Golf
    1 @ 16.54 ech	CV Boot kit, for 100mm (3.93 inch) diameter joint Volkswagen Golf
    1 @ 17.64 ech	CV Boot kit, for 100mm (3.93 inch) diameter joint Volkswagen Golf
    4 @ 3.00 ech	Bolt, strut mounting. M12x1.5x58mm Volkswagen Golf
    1 @ 43.00 ech	Ignition wire removal tool Volkswagen Golf
    2 @ 17.09 ech	C.V. Boot kit. Includes new boot, circlips, grease, clamps, and axle nut. Volkswagen Golf
    __________________
    $607.84 SUBTOTAL
    Sep 2006
    Did you order yourself a radiator hose
    MODS- TOO MANY
    Sep 2006
    Australia?
    There will be one for sale very soon
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by vwthunder View Post
    One of the local places is going to make me up one, that and the place I'm ordering from didn't have them otherwise I probably would have
