Results 1 to 10 of 13
Thread: crap blowing out of aircon vents
    Jan 2007
    brisbane QLD
    Hey guys we have a '97 GL with brown foam blowing out of the aircon vents. It's like they went into a unions meeting and said "let's get outta here", all just decided to quit on the same day.
    Only thing I can do is vacuum it, but last week they had a second ambush.
    Now we're afraid to use the aircon, fearing teh stuff's poisonous or something. How do you get rid of this crap!
    Jan 2007
    Hahahaha oh dear, fortunately for you thats just the sealing sponge between the vents and other dash fixtures, it used to be yellow but has turned a deathly brown due to age, nothing to worry about. May I suggest to max out the air con and have all the doors open whilst running the car outside to get all of it, or better yet take out some the vents (piss easy) and clean them out yourself!
    Jan 2008
    Strathfield,Sydney
    hahaha had this happen to me to little chunks come out now and then.with mine u can actually see the sponge pressed up against the vent.
    76 Scirocco
    Nov 2006
    Central Coast, NSW
    hahaha yeh mine does that too. I turned the fans up full and sucked it all out with a vacuum.
    Dec 2007
    Ermington, Sydney
    Ditto on the deadly sponge from within the dash!!
    Mine's done it a fair bit; don't worry about it mate just try and blast it all out
    Nov 2008
    Arundel QLD
    Quote Originally Posted by Lams View Post
    I have the same problem it gets stuck in the vents then you have to try and get it out
    Dec 2006
    Kilsyth, VIC
    It all comes out eventually... till some more comes out...
    Aug 2007
    Main culprit for this is oil from the Evaporator. This along with condensation through time breakes down the foam. Most A4s i do Evaps on now i strip it all off and stick new 3M foam to the blend door. There is a disadvantage along with the crap flying out of the vents. Remember it is a blend door, so if you have foam breaking down you will also have heat blend. Drops the cooling efficiency in the cabin. Gives the same impression as a stuck heater valve.
    Jmac
    Alba European
    Jan 2007
    brisbane QLD
    thanks guys. I have found the best solution, but it's a bit optimestic. We bought some new Pirellis for the car over the weekend so the aircon problem may go away if it becomes a Pirelli GTI
    Another problem, headlining is hanging down, how have you tackled that one?
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
    Sep 2006
    West Sydney
