Results 1 to 10 of 13
Thread: Rust in the Mk3
    May 2007
    North Rocks
    Rust in the Mk3
    Just thought I'd let everyone know about a little rust problem I had.
    A patch bubbled up on both sides of the car in the lower back door sill, basically when you open the door and you look straight down, that bit there. I forgot to take photos, but have now had it fixed. The chap who did the repairs basically said that it looked more than likely that it was a manufacturing fault and it has taken 12 years to final eat through, especially since it appeared on both sides of the car. There were no signs of damage by any previous owners.
    It cost $500 to fix, one side was worse than the other and had to have a piece cut out and welded back in its place.
    Has anybody else had these rust spots. Mine is a 96 GL.
    Sep 2006
    West Sydney
    '95-made '96-complianced GL here, and I had the same problems, except I got to it before it started eating through. It was just simple surface rust which I converted, sanded down and filled over. Mine was on both front sides but only on one of the rears. The spot that the rust started surfacing up was congruent with all the other sides that had rust, which made me think it was a manufacturing fault too and not because my car was in a previous accident and was patched up badly.
    Jan 2007
    Exact same thing on mine too, started eating at the sill, and for some reason started rotting the inside of the door near the sill contact surface as well. Must be a manufacturing fault as I can't see how it would get there. I got the whole thing cut out and repainted on both the door and the sill for $400.
    May 2007
    North Rocks
    Well there you go. Mine is actually 95 made 96 compliance too.
    Sep 2006
    West Sydney
    The seal that goes over it may be the culprit here... after rainy days, quite a lot of moisture gets trapped up in there.
    Dec 2007
    Ermington, Sydney
    I know it's a manufacturing fault, but that still sounds spooky!
    Jan 2007
    Quote Originally Posted by rayray086 View Post
    Yeah I'd say the same thing happened to mine, the seals have since been changed but it looks like the problem was diagnosed a bit too late and hence the problem developed. Another problem spot is under the side skirts, mine were fortunately free of rust or blemishes of any sort...
    Dec 2006
    Kilsyth, VIC
    Maybe I should keep on eye on that in mine since it's complianced 1/96...
    Jan 2007
    Quote Originally Posted by The_Hawk View Post
    I suggest you do, telltale signs such as grease and discolouring around the sill can save you much heartache later down the track. Also mines a 12/97 compliance, just shows how nothing really changed even until the end
    Jan 2008
    Mines a 94 . i think i'm gonna have a good look all over asap. Might even rip the side skirts off and check under there. any other areas recommended?
