Ive ran into a problem, as i try and start the car it turns over ans then cuts off, i have had this problem before but i fixed it with a new immobiliser coil (thing that is attached to the ignition coil) now 10 months later the same symptoms but not the same fix, i have replaced the immobiliser coil with 2 used ones, and have also replaced the box (where the immobiliser coil plugs into) iv'e checked all the fuses in the footwell and the relays appear to be ok (not sure how to check them)
VAG-COM scan came up with an error in the immobiliser "low signal" not entirely sure where else i could look.
Any help would be greatly appreciated.
Thanks in advance
