What heads fit a 2e 2 litre bottom end?
With a bit of luck I'll get a 91 MK2 by the end of the month and it currently has a 2e bottom end under the standard head. Long term plan is to convert it to run on LPG because I do over 800 k's a week and gas is cheap. Running a gas carby also makes it easier to fix if I break down.
Since it will be running on gas I don't have to worry about any of the injection or engine management systems so swapping to a 16v head should be an easy job.
What heads suit the 2e block, give better performance and don't cost the earth?
Paul
- You may not post replies
- You may not edit your posts
Forum Rules
