Results 1 to 4 of 4
Thread: Front washers help!!!
    Dec 2008
    Bentleigh, Melbourne
    Hi guys,
    Front washers for the wipers aren't working.
    I tested the pump.. it works fine.
    Cleaned all connecting points on the pump and the interior wiper stalk...
    And it still doesn't work!!!
    Note: front and rear wipers and rear washer pump works fine
    Jun 2011
    Sydney NSW
    Check the piping and see if you can locate a non-return valve. It has probably failed and so the pump cannot overcome the loss.
    Dec 2008
    i am thinking there's a break in the electrical circuit somewhere??
    when i flick the stalk to put the washers on... nothing happens,
    but if i hard wire it to the battery.. it works perfectly
    Jan 2007
    It could be a break in the line.
    My licence plate light has been out for a year and it ended up being a cable that had rubbed right through and snapped.
    Have a poke around for a broken electrical cable. Also check your fuse? I guess you done that already.
    07 GTI
    APR stage II
