Bowdens Own Wipe Out. No clogging, good bug removal, good wiper lubrication, no residue left on paintwork. The best product IMO is the genuine VW additive, but the Bowdens Own seems to be a very good alternative.
what additives are people using in their cars?
The previous owner of my Octavia had issues with the system gumming up and I'm in the process of replacing a clogged headlight washer jet.
Skoda has a listing for a small bottle of concentrate additive, but apparently they're not allowed to sell it.
I'm not going to be taking my car to them for servicing, so am trying to figure my options.
thanks
Steve
I use the genuine VW additive in mine (a blue colour) but any good quality additive should be ok. As mentioned above, the Bowdens products are very good and readily available.
I have heard stories of some of the RainX additives causing blockages over time. I think the hydrophobic properties of the RainX tend to crystallise over time - so best to avoid those.
Also check your spray nozzles are unblocked (use a pin etc) as they commonly block up also causing a bad spray pattern/poor flow.
2017 Ford Fiesta ST
Is any person able to buy the VW additive? Seems Skoda are trying to force owners to go to them for servicing and I daresay they would top up for free. And likely it's the same stuff...
I have always used this stuff, although last time around they (apparently) didn't have it anymore and I got the summer concentrate bottle, but I still haven't used it as I've only just finished my last bottle of the original fluid.
In a vehicle without headlight washers or rear window washers it probably doesn't matter too much since the plumbing is pretty simple... in the van I consider it a pretty cheap insurance policy against fouling the lines (11 years in it's still good).
I like the alcohol based VW fluid but VW no longer carry it. Found some at an independent service guy so have stocked up on a couple of litres
Tig 162 R-Line; Audi TT
This works great
SCA Windscreen Wash Concentrate 1L | Supercheap Auto
I mix it a bit stronger than it says on the bottle.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Over the course of five decades I have used a mixture of predominantly water with a dash of methylated spirits and only one or two drops of dishwashing liquid. Works a treat and is cheap as chips. Cheers-John
Now days, I mainly use the Rainex windscreen washer additive. It's not the cheapest, but I never had to scrub any ice from the windscreen in the winter times.
