yeps i let her idle till the auto choke backs off then drive her nice till the 90 degree mark
I think it runs better and sounds better without warming it up but I still wait about 20 secs or so before driving off.![]()
As has been said, modern cars should be driven moderately until the temp is at operating temperature.
You should never leave a new car idling for long or run it on a light load as you can glaze the bores. I also think this is true to a degree for a car that has been run in but idles constantly.
2000 Mk IV GTI
Start car & drive out of garage. Press garage remote & wait at top of driveway long enough for door to close, put on seatbelt, plug in phone, adjust A/C & get comfy. Drive off & try and keep revs below 3000rpm until the temp gauge is halfway.
Sitting in the drive idling might warm the engine but it does nothing for the gearbox oil, wheel bearing grease, brakes, etc.
I disagree.
It takes 15mins from start up for my Oil Temp gauge to reach 90-100 degree's where it stays for normal driving. It takes 5mins for the water temp gauge to reach middle(90) and by this time the oil temp still hasn't moved from 60 degrees(bottom of the dial).
I start mine and let the auto choke finish then I move off keeping the revs down for the first 5 mins.
lol how can you disagree if volkswagen have this feature on there t4 caravelle?
dom
Is my Polo the same as a t4 caravelle?
umm.... im sure you can work that out yourself
