Results 1 to 7 of 7
Thread: Brake pad recommendations
    Having trouble figuring what brand to buy for my golf, I have t2 dba rotors to go just need figure out some good pads
    Look on Brakes Direct website - heaps to choose from. Depends on what you are looking for (eg low dust, general street use, performance etc).
    https://brakesdirect.com.au/aus/cata...=2.0L%2B103TDI
    I recently purchased a set of Akebono Euro Ceramic pads for my SQ5 as i wanted a low dust pad (stock pads are ridiculously dusty) and so far have been pleasantly surprised with just how low dust they are. ATE also make a ceramic pad which are popular with members on here for the same low dust reasons.
    If you want a more performance oriented pad then perhaps look at Forza, Bremtec, Remsa or even the new range of pads from DBA. Ive used both Remsa and Bremtec previously and they were fine.
    2017 Ford Fiesta ST
    Erskineville, NSW
    bremtec pro series (whatever it's called) on the Honda I did not like. Wooden pedal and no retardation.
    Wagner I like for light duty suburban use. Not as dusty as OEM but not as good as ceramic.
    You might specify if you drive fast, around town, short trips, etc.
    My pad requirements are different from most. I do short trips and need immediate cold stop performance. They need to be quiet under all conditions. I've never cooked my brakes so high temp resistance isn't needed. I only do 5000km/pa so long life isn't a priority.
    Bad spec=bad result
    Hey should mention %99 of driving is on the highway which winds abit and is common for kangaroos to jump out at ya I had some people recommended bendix euro plus so I caved an bought locally as I wanna do this weekend
    Quote Originally Posted by Stenno93 View Post
    A standard street pad is what you want for highway driving with the odd emergency braking situation - it will have the best bite and performance from cold.
    The Bendix pads will do the job just fine.
    2017 Ford Fiesta ST
    Good to hear thanks mate
    Jan 2019
    Just don't fall into the trap of getting TEXTAR pads... mega dusty and average performance.
