Results 1 to 10 of 18
Thread: wheels spacers
    Apr 2009
    wheels spacers
    hey everyone
    Just about to order some new wheels but they are a different offset
    my standard offset is 35mm and the new wheels are 45mm so i thinking about using a spacer
    They said i could get away with about a 3 mm
    what do you think
    The Mk2 GTI Baby
    Jul 2005
    Newcastle, NSW
    35mm is how it sits now with how many inch rim?
    45mm offset and any spacing varies considerably with the rims width. if they are the same it will bring the wheel inside the guards more by 10mm and then a 3mm spacer ends up with you being 7mm further inside the guards than you are now.
    Apr 2009
    so not really a good idea??????
    The Mk2 GTI Baby
    Nov 2005
    how wide are the new wheels?
    it all depends on if they are the same width as your current wheels
    dom
    Apr 2009
    Quote Originally Posted by WABIT View Post
    dom
    they are going to be an ince wider
    The Mk2 GTI Baby
    Nov 2005
    Quote Originally Posted by tud82 View Post
    in saying that, and the specs you gave me, it works out to be
    23mm LESS inner clearance
    EXTEND an extra 3mm outer position
    thats from a 16x7 ET35 to an inch wider and ET45 offset
    Dec 2007
    Ermington, Sydney
    what do you actually need/want to use the spacers for?
    if you need to clear brakes, or the suspension, then just get the new wheels and work out how much you need.
    or, tell us what wheels and someone will probably be able to help
