Results 1 to 7 of 7
Thread: What stud size do I get for my adapters??
    Jul 2012
    Need some help please
    I am needing to order some adapters from Adaptec and am not sure of what stud size to select.
    Thickness of the adapter I need is 28mm...if that helps.
    Jul 2012
    These are the selections:
    What stud size do I get for my adapters??-picture1-jpg
    What pcd you going to? For jap you could 14x1.5 or 12x1.25.
    Generally your 5x112 wheels are going to be 14mm, so might as well go with that (haVe only seen one set with 12mm holes...)
    Porsche would be all 14mm I'd imagine.
    Just get them to put in standard length, the only time Iv seen this wasn't right Was on some merc wheels where the studs are required to be longer
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2012
    Thanks for that.
    Will measure the holes when I get home - they are jap wheels.
    Actually just saw the 12x1.25 and 12x1.5.. not sure which of those two is standard for jap actually
    Won't make any difference unless you want to buy a certain brand of after market wheel nut I guess
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2012
    ok thanks
    Jul 2011
    My silvia was 12x1.25 as are skylines
