Results 1 to 10 of 11
Thread: Advice on Seating wheel studs
    nsw
    My wheel stud conversion kit finally arrived from Motorsport hardware. When fitting the wheel studs (M14) is there a recommended torque spec for seating? Do I need a dab of loctite too?
    Dec 2008
    Sydney/Canberra
    What do they look like?
    It might be best to contact the manufacturer about the best way to torque them down.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    nsw
    long nosed with allen key fitment. A shoulder between the seated part and the actual stud that the rim fits on.
    82mm Black Bullet Nose Race Stud Kit 14x1.5 - Motorsport Hardware
    Apr 2010
    granville, sydney
    looks like other guys are dabbing loctite and torquing it up to 50ft-lbs
    cw.mkv.gti.034ms,s2+
    Erskineville, NSW
    50ft/lb is only 68Nm. The wheel bolts are usually 120Nm aren't they? I'd go at least to that with a dab of loktite.
    Pacific Paradise QLD
    Sounds a bit much Passats are 90nm
    Apr 2010
    granville, sydney
    i just figured it came down to the mating surface, the wheel bolts have a much larger area against the wheel lines than just the stud going into the hub
    Erskineville, NSW
    Golfs 120Nm - which isn't very tight.
    Apr 2010
    granville, sydney
    ecs' kit seems to suggest threadlocker + 15nm is enough
    Tis too on reflection was my Landcruiser mags? that were only 90 Checked the torque wrench in my boot and its set at 120
