Page 8 of 8 FirstFirst ... 678
Results 71 to 74 of 74
Thread: Playing with an Audi SQ5 TDI
  1. #71
    Lucas - Massive improvement Lucas last time! I need to do the same again on my SQ5 How do you get those bolts at the back of the manifold out? I really struggled to get them out and back in. Do you have any special tools?
    Also finally got around to fitting (last weekend) the Akebono rear pads and Zimmermann drilled disc brakes, only had a short drive so far, but so far so good . Now got to decide if to get drilled discs for the front or not. Just worried if the holes will wear down the pads quicker then a flat disc?
    Bit shocked by some of the corrosion I found behind the back wheels. You are lucky you don't have harsh wet and cold Scottish winters with horrid salt thrown over the roads
  2. #72
    You just need a long extension (about 30cm) to get at those bolts. They are not easy without the right tool as there is very little room. Also a magnet pickup tool is a great help for holding onto the bolts while removing/reinstalling so they dont drop into the never never.
    Good to hear you got the rear brakes sorted. May as well get matching drilled disks for the front so it all matches.
    Quote Originally Posted by SQ5Raphster View Post
    2015 Mk7 GTI Performance
  3. #73
    Do you use a rigid or flexible extension?
  4. #74
    I have both types, but cant remember which one was better to reach those bolts sorry. It may have been the rigid one I think.
